Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie-informatie en ondersteuning voor achterloopmaaiers geproduceerd door de Toro Company.
How to replace cord
What size of wrench/socket is needed to remove cover?
Is dit een goede vraag?
Score 2
3 opmerkingen:
Would you mind giving us the model number?
door Deel
ph-xt675-2011 pull cord wont rewind
door Deel
need 10mm socket to take top off
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Well that depends on the size of engine u have . (I'm sorry if my answer sounds rude kk) Now, hopefully u have ur Sockets still in their boxes that they came in. If u do just use ur common sense and take one socket that u might think will fit. If it doesn't then try another one. And eventually u will find the right one that fits.
Was dit antwoord nuttig?
2 opmerkingen:
Would that be metric or standard sockets? Would a cresent wrench work? Why does the cover need to be removed? What are they trying to fix? Do they need a guide? Shouldn't you find out what model it is first as Toro has been making engines for over 100 years? Is this a gas or electric engine? Is she looking for a replacement electric cord or a replacement engine start cord for a gasoline operated machine? Should she go here and enter her model number to find the replacement part? https://www.torodealer.com/en-US/Pages/p...
" 'Course that's just my opinion, I could be wrong."
door Deel
No your not wrong. All your questions are Valid ones
door Deel
the cord you pull to start the engine is locked . What do I need to do to free the cord?
Voeg je antwoord toe
mojokatt57 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 1,041
