Ga door naar hoofdinhoud
A 4G smartphone manufactured in 2011 by Motorola. Distributed by Sprint.
8 Vragen Bekijk alle
My phone just went off
my phone just went off while charging for now nothing appears on screan i have tried taking it to be repared and nothing happens but when put to a charger its getting hot at the back what may be the problem
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Marvin,
Sorry to hear about your phone. Check out this troubleshooting page for your device. It sounds like the battery may need to be replaced, but thankfully the part is cheap and repair seems pretty simple! You can use this guide and do the swap yourself. You can also find the replacement battery here.
Good luck and let us know if this helped!
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
marvin chisala zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 70
