Ga door naar hoofdinhoud
Repair guides and support for phones manufactured by Jiayu.
8 Vragen Bekijk alle
Phone dead after connecting wires to wrong pin on micro usb charger
I was in an emergency situation where i needed to charge my smartphone and i only have a broken usb wire and a mirco usb conncetor. I connected the positive and negitive wires to the pins on microusb connector. it worked fine for a few seconds but unluckily the positive wire slipped and connected to one of data pins. The phone turned off. Now as soon as i insert the battery the phone blinks every time i press power buttton and led light turns on or blink in 2 different colors.
I need to ask what parts could possibly be damaged or how can i check the damaged part as i cant sent it back to china to repair and prefer to order the damaged part instead.?
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@mtk there is not a particular part that will have failed. Any of the components along the dateline that got powered may have failed. Unless you disassemble your phone, have a schematic and a board layout, there really is no way to fix it.
Was dit antwoord nuttig?
Score 3
if i change the power acpi or motherboard can it be useful in the same case
Voeg je antwoord toe
Muhammad Tehseen Khalid zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 555
