Ga door naar hoofdinhoud
Koosh Vortex Tornado is a spring loaded toy gun that fires Koosh Spinfire rings.
3 Vragen Bekijk alle
Why does the barrel shield move freely on the gun?
The barrel shield that you pull back to insert the firing rings is not stable. It slides back and forth on the gun and does not hold its position. How can I fix this so the piece holds its position and returns to covering the barrel once I insert the ring?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The return spring has most likely been disconnected from its original mounting spot. This prevents the shield from returning to its original position.
To fix this issue, you must open up the gun and find the faulty spring. Reattach the spring to its original position and the shield should start working properly.
See our troubleshooting page liked below for more information:
Koosh Vortex Tornado Troubleshooting
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Jordon Roseman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 50
