keurig elite works only with water not k cups
The keurig works fine if you only use water. As soon as you put a k cup itmakes noise but does not brew . I have cleaned every orfice on the unit, including blowing out hoses inside the unit,.Works great if you only want hot water. HELP STARTING TO SHAKE,,,
Is dit een goede vraag?
15 opmerkingen
if your keurig will work with just got water but will not work with a k cup inserted, the issue is the exit needle on the bottom. I just racked my brain for 3 days with this issue. i took the entire machine apart and then out it back together with no resolution. Wasn't until I put a paper clip thru the bottom needle that everything went back to normal....thank baby Jesus!
The reason the keurig was shutting off with a k cup inserted is because the water would enter the k cup but couldn't drain thru the bottom so all the grounds and water would back up into the top needle which is why the keurig shut off (safety feature)
If you have this issue and this fixes it, let me know!
door Tyler Buffington
Tyler! I had same issue. I tired your advice. Worked like a charm! Ty!
door Melanie Brega
My K Supreme still refuses to work. I too have clean every orifice. This is day four of repeating every step as videos show and as instructed.
I am at my wits end ?
door honiest
That just fixed my issue. Thank you!
door Keith Foisy
I just had the same problem and this resolved my issue, also. Thanks for posting what should have been obvious to me.
door Brian Gorham
10 commentaren meer tonen
