Ga door naar hoofdinhoud
Acer Aspire E 11 is an 11.6". System is equipped with a Celeron N2840 with 2GB of RAM. This laptops runs Windows 8.1 with Bing. This laptop uses 32GB of eMMC storage.
7 Vragen Bekijk alle
Why is my computer not starting when I press power?
I have tried pressing the power button several times but nothing is happening. I have already tried charging it. Does anyone have any ideas on what could be wrong?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
The first thing I would do is make sure your computer is plugged to the wall and then check the power indicator. If it is not lit, you are not getting any power to the computer. The battery could be low or not charging properly. Check all the connections from the wall to the AC adapter to the computer to make sure everything is connected. Try to recharge the battery a bit more if possible and next time you try to turn the computer on make sure you don't have anything connected to it at the ports.
If you have any further questions, please refer to the troubleshooting page.
Was dit antwoord nuttig?
Voeg je antwoord toe
Stephen Robinson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 377
