Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
Screen popped after replacement .
I replace the screen on a 5C and the screen pops off on the left side , and a less in right side . Sound like isn't in place correctly , but it is .
Never had this happen with any other model. Anyone know what's going on here and if there's a fix
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Its very typical with poor screen quality. You will likely find that the glass is actually "popping out" of the plastic frame. You could try to glue it with B-7000 or similar adhesive, but it may happen again. Higher quality screens have hot pressed frames, so the frame is very securely attached to the glass and this doesn't happen.
The only other possible cause which comes to mind, which would be if the glass is definitely not coming out of the frame, would be a swollen battery
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Sorry Ben we post at the same time :)
door
haha don't apologise :) you said the same as me anyway :)
door
The battery is ok .
I believe is the screen quality at this point .
Ty
door
Hi
I have this problem before where the glass separate from the frame. This is case of not good quality of the LCD/Digitizer. If that's the case you will need to replace the LCD again.
Hope this help
Score 2
Voeg je antwoord toe
lorfuma zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 204
