Ga door naar hoofdinhoud
Released September 2014, the LG G3 Vigor is smaller and cheaper than the LG G3.
Why won't my phone turn on?
I just tried to turn my G3 Vigor on and nothing happened. What should I do if it won't turn on?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
7 Antwoorden
Het nuttigste antwoord
Make sure that the phone is charged. It won't turn on when the battery is uncharged, so you need to plug the phone and charge it and see what would happen.
Was dit antwoord nuttig?
Score 1
Loose the phone,
Heat the board with solding paste( flux)
Let it get cool and jail the phone back.
Good luck..
Score 1
Hi Jared,
Check out this troubleshooting page for the LG G3 Vigor. If you're still having trouble with your phone, comment back with some more details about your issue ( Age of your phone, what solutions you've already tried, ect. ) and we'll continue to try and help. Good Luck!
1. Check the battery
2. Check the battery sensors
3. Make sure the power switch has water or other deposits
4- Activate the device using the material of the frying and heating a light at 350%
The reason for the sudden shutdown of the phone during use and battery is charged 100% without any external cause
Alexa will not answer
  • Make sure the battery is fully charged
  • Check if the charger is working properly
  • Check for the moisture on the phone
  • Boot the Nexus 5/5x in Recovery mode(Worked for me)
  • Go to the authorized repair store to fix the hardware issue
Source : https://fixyourandroid.com/fix/how-to-fi...
Voeg je antwoord toe
Jared Stickl zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 359
