Which adhesive to use on subwoofer rubber surround
Which glue to use to fix a tear in my subwoofer rubber surround
Is dit een goede vraag?
Black RTV ! I used it to rebuild 2-12 inch subs worked perfect without compromising any sound Subs are still working and sounding perfectly 5 year's later
Was dit antwoord nuttig?
My directions for replacement of old foam surround with butyl rubber surround.
(Do not use weldwood on foam! Foam will disintegrate)
I use Weldwood contact cement.
(Shoegoo is too thick for this application don't do it.)
Peel top ring carefully as you will reuse.
Keep all solvent and glue to only contact areas, do not leave any foam bits on cone.
Peel old foam with care not to damage cone or tear spider below. most time old foam will just pull or rub off easy, I brush acetone carefully to melt the rest off.
Pre brush clean at glue areas only with acetone, cone edge, basket ring then dry be sure to have removed old foam or rubber.
IMPORTANT: Start with basket ring, then cone edge. Your new butyl will ripple if you use too much or do it first.
Both parts glued now get promptly attached again with care to keep cone centered.
Glue top ring on and don't worry about perfect adhesion to cone yet just set it face down for 10 min.
check for proper adhesion to cone again after 10 min the hi spots should press and stick now.
You can recheck high spots a few more times till mid cure or 30 min.
Lastly you can flip the speaker over and use the same glue or even super glue to do a gap fill under your speaker cone edge assuring no air gaps. Do not put glue on the flexible suspension part.
I leave any repair like this alone before testing 24 hours but you can re mount after a hour.
I use black permatex gasket cement on cone tears.
Just did a recone on 4 eminence Lab12's using gorilla glue clear for spider/frame, surround/frame, and dust caps/cone, and some 5 minute epoxy for the cone/voicecoil/spider joint.
Eminence has been using what appears to be hot melt glue on the soft parts to frame connections. The gorilla clear seems to make a great connection. It also worked beautifully on the dustcaps. Would be nice to have a smaller nozzle for the caps, as the bottle leaves about a 1/4" wide glue bead. I like mine a little thinner. Not a deal breaker. Just not my personal ideal.
I also did a test bead and knifed it off with a utility knife to see how the next recone might go. Cut very similarly to the hot melt glue from the factory.
Bottom line: need to recone and dont have a week to wait on getting some latex glue? Gorilla glue clear is a great alternative. Definitely cleans up better than the old black latex adhesive.
Not sure I'd stay from using epoxy on the voice coil connection... but it works well on everything else.
I've been reconing speakers for 20+ years and lately, since my old supplier is no longer in business, I have been using 3M #847 gasket adhesive. This stays pliable so you don't need to worry about the glue getting stiff and cracking and it gives you a bit of time to get the cone positioned correctly if you move it a bit while applying the glue. It comes in 2 colors, yellow and brown. I use the brown. Also, this is good enough to not worry about getting all of the old surround off. Yes, it needs to be as clean as possible, but a little here and there won't make a difference. I have used this to attach spiders as well.
There is special glue for attaching the cone to the spider and the dust cover to the cone though. Don't use this stuff for that.
Dan
I'm going to be trying 3m's windshield adhesive to see how that works out, if it's a tear I'd use 3m's super weatherstrip adhesive the black stuff apparently goes on really runny, and dries like rubber or silicone. it'd also blend on anything black so should be good for 90% of the rubber rings subs have.
Probably gorilla glue.
no u need something flexable like fabric glue . U might need to put a few layers inside and out .Using something flexable will reduce noise that a nonflexabble glue will make also a nonflex glue will just tear again...
Boys, this is an answer. Albeit a bad one. Just down vote it. It's wrong to remove it as not an answer.
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 123
Altijd: 39,850
1 Opmerking
RTV silicone is what you might try. Also refer to the ifix it guide Subwoofer Rubberen Rand Reparatie
door Michael Inge
