Ga door naar hoofdinhoud
Model A1288 / 8, 16, or 32 GB capacity
451 Vragen Bekijk alle
Vraag afgerond
HELP! Touch screen not responding after water damage.
After leaving my water bottle in my bag, my iPod got wet. Stupid of me, but I left it on and tried to check if the music still worked. After awhile, I tried to turn it off, but the touch screen wouldn't work. So I left it in a bowl of rice for a couple of days and found that the iPod turned on and everything was great until I tried to unlock my iPod. I again put it in rice (thinking that the water that had not been absorbed by the water would be absorbed), and the touch screen is still not working!! I then tried restoring it, which was just a pain in the butt and my iPod won't restart for some reason >.<.
Any pointer/suggestions? Should I put it in rice again? Or should I just fork up the money to get it repaired by Apple or any other company??
Please and thank you!!
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
yo mommas so fatttttttt
Was dit antwoord nuttig?
Score 3
1 Opmerking:
and "yo momma" did not teach you any manners
door
You should try replacing the front panel / digitizer assembly (which contains the touch sensor).
iPod touch (Gen 2) Front Panel Assembly Afbeelding
Product
$29.99
Score 1
I've replaced the front/panel digitizer assembly however, i'm stuck with same issue. Touch screen is still not working. I've done almost everything i can...I'm starting to think i'm "SOL" or is there anything else i should try....please help
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 7,102
