Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
head phone jack repair
how do I know if it's a thick or thin version? I need to replace the headphone jack
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Stephen LaScola you could use a kitchen scale and weigh your iPod The "thick" is ~5.7ounce's/163g and the "thin" is ~4.9 ounce's/137g. Check your serial number on this site and see what it tells you.
Was dit antwoord nuttig?
Score 2
Depends on your capacity.
If i'm not mistaken, the 80GB is the thin version, while the 120GB is the thick version.
Well that is either a 2nd or 3rd GEN I think that you should get a new one
Score -1
3 opmerkingen:
minecraft pro good game why would you suggest to replace it? If you can fix it there is absolutely no reason to get a new one. Also, there is absolutely no reason for people having to text you to receive an answer. We answer questions on this forums so everyone benefits
door
Because it takes up too much data to be online 24/7
door
Whoa, neither your answer nor your comment makes any sense. You may want to review what you are saying. iPod Classic "too much data to be online 24/7" does not compute.....
door
Voeg je antwoord toe
Stephen LaScola zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 135
