How to repace ignition coil
how to replace my ignition coil 2003 element
Is dit een goede vraag?
This does not have a single coil instead it has coil packs on top of each spark plug . They are easy to change out usually held down by a bolt and once removed you disconnect the wire harness and pull the boot. Did you get a error code on the OBDII or why are you wanting to change the coil . A misfire will be coded for you and will tell which one needs to be replaced Usually a po300-304 . you will need the fireing order to determine which coil pack to replace. when doing the replace its a good idea to replace the spark plug at the same time . Hope this helps
Was dit antwoord nuttig?
there may be a cover over the valves that hides the plugs and coil packs depending on the year of the car
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 1,593
1 Opmerking
I Have The Same problem for 2005 Honda Element
door drealove2 Deel
