Ga door naar hoofdinhoud
15,6 inch beeldscherm. Herkenbaar aan modelcode: NP470R5E-K02UB. Dit apparaat werd uitgebracht in augustus 2013.
Do not attempt keyboard replacement.
Hey everyone,
This isn't so much a question as a word of advise. Do NOT attempt to replace the keyboard on this device without purchasing a new palmrest/top case as well. The keyboard is held in by what looks like plastic rivets, and is VERY difficult to replace on your own. I've attempted a keyboard-only repair a few times, and I won't let it happen again. It takes much too long to tear off all the plastic rivets and glue the new keyboard down, and you end up with a less than satisfactory repair every time.
Is dit een goede vraag?
Score 4
1 Opmerking
Where did you order the palmrest/top case that you recommended. If you could provide the part number, that might be helpful if a future repair is required by someone who reviews the post.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I had the same experience. Had to completely disassemble the laptop to get to the keyboard, then cut off the plastic rivets with a box cutter to remove it. Well, OK, my student worker did. I supervised. It's nice to have minions. It did turn out well but took a few hours.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
hi brianstrech,
how did you guys glue the keyboard back?
door
Voeg je antwoord toe
Max Rysdon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 1,933
