Replace Fusion drive for a SSD
iMac 27" 5k late 2015
Replacing the HD from a Fusion iMac for an SSD samsung 850 EVO or PRO, Will I have the cooler fan speed up problem?
Will I need the "OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later"?
By the way, it is hard to close the iMac display after opened? Using the ifixit.com "Adhesive Strips" will it looks sealed as came from the factory?
Atualizar (06-02-2016)
Yeah. Really seems I will need the thermal sensor. If I go on this for sure I will include in my list of purchases in order don't need to open it twice.
I discovered that the imac came with 2 free slots for a certain kind of ssd. I will research if isn't better to put those ssd there instead of replacing the other.
About remove the old adhesive. Any tips of how I can get a perfect cleaning? Isopropyl alcohol may help me? Or should I stand only scratching the adhesive with some spatula?
Is dit een goede vraag?
2 opmerkingen
Really? I take it that you have never been into one of these.
door mayer
Here's a few sources: Plastic razor blades to scrape off the old strips and here's the cleaner I use: Goo Gone which I use on a microfiber cleaning cloth: Disposable micro cloth towels
door Dan
