Ga door naar hoofdinhoud
The Canon EOS Rebel T3i, released in March 2011, can be identified by its SKU (SKU:5169BO32). Also known as the EOS 600D and the EOS Kiss X5, this camera is a Canon Digital SLR with 18 megapixels.
Eyepiece is not working.
One of the lens components inside the eyepiece is out of place after a bump. Can it be fixed or must the eyepiece be replaced?
Is dit een goede vraag?
Score 3
2 opmerkingen:
@jlaurent, I have the same situation, and just asked if anybody knew whether the top cover guide can give us access to the lens compartment.
If you are interested, it's here: How to get access to fix the optical view finder lens?
If you've fixed it or had it fixed, how did you do it? Thanks for sharing
door
@jlaurent, I was able to fix my viewfinder, with advice from @flyingdutchman, you can see his answer here: How to get access to fix the optical view finder lens?.
It is the answer I have accepted. Hope it helps!
door
Voeg een opmerking toe
1 Antwoord
Please see @flyingdutchman 's answer to this question: How to get access to fix the optical view finder lens?
You will have access to your viewfinder, and will be able to assess whether it needs replacing or just popping a lens back in.
Was dit antwoord nuttig?
Voeg je antwoord toe
Julius Laurent zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 945
