Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Uitgebracht in februari 2015. Modelnummers XT1526, XT1527, XT1514, XT1523 en XT1506.
problems with screen cables
Good afternoon, after re-replacing The screen of a client, I'm facing some problems with the touch screen technology... After I've taken off the screen glass, only part of the touch sensing was working (bottom-left part of the phone), I've tried taking off the LCD and cleaning up the internals with a towel, but after I've reassembled the LCD, the touch was completely gone. I think (and wish) that it is only a cable positioning problem, but I can't fix it... Need help.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
I know you don't to hear this, but it sounds like you probably have a faulty digitizer on your hands and will have to source another. Just to be sure though, make sure all the connectors are properly seated. If it's a ribbon style connectors, trying cleaning the ends of it with a cotton swab and 91% isopropyl. If it's the FPC type, have a look at it under a microscope to make sure its not missing any pins
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Sam Kultz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 668
