Ga door naar hoofdinhoud
De Wii werd in november 2006 uitgebracht in Noord-Amerika en was Nintendo's eerste spelconsole voor thuis die direct internetconnectiviteit ondersteunde, met ondersteuning voor zowel online games als de digitale distributie van games en media-applicaties via het Wii-winkelkanaal.
Fix cracked wii remote front
I cracked the wii remote front infrared panel while bowling, now it doesn't point. Can this be fixed? All other functions are still working.
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
The tri-wing needed to open your remote is also available in iFixit's driver kits.
[gekoppeld product ontbreekt of is uitgeschakeld: IF145-022]
[gekoppeld product ontbreekt of is uitgeschakeld: IF145-028]
Was dit antwoord nuttig?
Score 2
1 Opmerking:
door
You can try just unscrewing the case and removing the front cover and see if that helps. The front cover is just a filter that only passes infrared light (and keeps dust out). But if you damaged the sensor inside, then you'll need a new Wii remote. To unscrew the case, I believe you need a tri-wing screwdriver, which you can get at Ebay. If the sensor is damaged, you can sell the remote to a hacker who only needs it for the accelerometer.
Score 1
This is what I did to my remote and it works perfect http://howtofixstuff.blogspot.ca/2013/08...
The front of the wii remote had a cracked screen because my older sister or brother and me were playing just dance 1 2 3 or 4 she or he kept on hiting it out of my hand. XD is that your problem.
Follow a guide for your wii remote, but before that, make sure you buy a replacement case/screen.
Voeg je antwoord toe
Val zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 18
Altijd: 6,832
