Ga door naar hoofdinhoud
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 Vragen Bekijk alle
Vraag afgerond
2010 iMac fan replacement
I took my imac to geek squad and they ran a diagnostics test which says that the "fan is failing". I asked them which one but they say it doesn't say. I checked online and found out it has two fans.
A couple of years ago I installed an app that accelerates and also slows the fan down if you want to. I accelerated the fan speed thinking this was a good a idea to do during the hot summer. I believe this is what has damaged the fan. The problem is I don't know which fan is damaged. Can someone give me an idea. I was thinking of replacing both fans but one of the fans looks easy to change but the smaller one not so much.
Can someone give me some advice.
Is dit een goede vraag?
5 opmerkingen
There were seven mid 2010 iMac models. Which one do you have?
door
mid 2010
21.5-inch (1920 x 1080)
ATI Radeon HD 4670 256 MB
door
That narrows it to three machines but it may work.
door
If you let me know where to find the model ID is I can let you know.
I've looked into the info but this is the information I get. Serial NumberW8035C5ADAS
door
Apple iMac "Core i3" 3.06 21.5-Inch (Mid-2010) Specs
Identifiers: Mid-2010 - MC508LL/A - iMac11,2 - A1311 - 2389
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Next question, has the hard drive been changed? Then, have you disabled your third party software that controls the fans?
CPU Fan
iMac Intel 21.5" EMC 2389 CPU Fan Replacement
Optical drive Fan:
iMac Intel 21.5" EMC 2389 Optical Drive Fan Replacement
iMac Intel 21.5" EMC 2389 CPU Fan Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
iMac Intel 21.5" EMC 2389 Optical Drive Fan Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
No it's never been opened inside for any repairs since I bought it I treat it very well. It's the first time I have a problem with it.
door
The hard drive has never been changed.
What I did do which might have damaged the fan was that I installed an app to make the fan go faster. I suspect that might have damaged the fan. But which fan is damaged is the problem.
door
I know the hard drive question seemed like a non sequitur but it's not. Open it, blow out the fans you can get to with canned air, Do it outside. Blow up the vent passages. The cleanest houses have the dirtiest computers because vacuum cleaners keep dust suspended in the air and you computer just sucks it up. Check the heat sensor on the hard drive to see if it has fallen off. Turn the machine on to try to determine which fan is not operating. Fan failure seldom occurs.
door
Thank you so much Mr Mayer, my son in law is coming in a few days and I'll give him this information. He knows a lot about computers and fixes minor software problems for me but he lives hours away. This information is great and I know he will understand your suggestions. Thank you for you time.
Philip
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 2,034
