2010 iMac fan replacement
I took my imac to geek squad and they ran a diagnostics test which says that the "fan is failing". I asked them which one but they say it doesn't say. I checked online and found out it has two fans.
A couple of years ago I installed an app that accelerates and also slows the fan down if you want to. I accelerated the fan speed thinking this was a good a idea to do during the hot summer. I believe this is what has damaged the fan. The problem is I don't know which fan is damaged. Can someone give me an idea. I was thinking of replacing both fans but one of the fans looks easy to change but the smaller one not so much.
Can someone give me some advice.
Is dit een goede vraag?
5 opmerkingen
There were seven mid 2010 iMac models. Which one do you have?
door mayer
mid 2010
21.5-inch (1920 x 1080)
ATI Radeon HD 4670 256 MB
door cathefelix
That narrows it to three machines but it may work.
door mayer
If you let me know where to find the model ID is I can let you know.
I've looked into the info but this is the information I get. Serial NumberW8035C5ADAS
door cathefelix
Apple iMac "Core i3" 3.06 21.5-Inch (Mid-2010) Specs
Identifiers: Mid-2010 - MC508LL/A - iMac11,2 - A1311 - 2389
door mayer
