Ga door naar hoofdinhoud
Een spelcomputer die in 1985 door Nintendo in Noord-Amerika werd uitgebracht, genaamd het Nintendo Entertainment System, model NES-001.
Is it Safe to use Isopropyl Alcohol to clean cartridges?
I want to clean the contact points on my old NES Carts. I thought to do this with a little bit of Isopropyl Alcohol (Rubbing Alcohol) and a Q-Tip, or perhaps a micro-fiber cloth.
I don't think this would damage the board, but the NES Carts have a label on the back that tell you not to do this so I am a bit hesitant to try it.
Is dit een goede vraag?
Score 9
12 opmerkingen
I'm pretty sure you mean "Isopropyl" alcohol, Isopropyl relates to the hydrocarbon, whereas "isotopic" refers to varying masses of the same element based upon different numbers of neutrons.
door
NO. It will rust the pins making it useless, use only a scrubing pad, a soft one and clean them like that, do not blow on them since it will also rust, take apart the cartridge and use counter top cleaner, trust me, i works well, it you tried everything, its just that the board is shorted out and will not work at all, so its dead, so yeah
door
higher concentration alcohol will not rust the pins or make it useless. get the purest rubbing alcohol you can find (50%+) and it will be just fine. i own 1100 games and been collecting for 25 years and none of them have EVER rusted or corroded from this method. Just make sure you use the dry and of the q-tip to soak up any excess when you are done and youll be fine.
door
If you think isopropyl will cause rust, you need to retake your science studies.
door
it works well and you can get surgical alcohol sometime called rubbing alcohol from most chemists/drugs stores it will not cause corrosion as the contacts are non reactive to alcohol.
door
7 commentaren meer tonen
Voeg een opmerking toe
12 Antwoorden
Gekozen oplossing
well if you open up the cartridge you can see how dirty they are generally, if they are REALLY dirty then yes it's fine to use alcohol on it and Q-Tip's (is that an American thing?) we call them cotton buds in the UK ;p
Another good method is using a pencil eraser on them, i've done that a good few times, just make sure there is no eraser shavings left on the cart anywhere.
Was dit antwoord nuttig?
Score 12
7 opmerkingen:
+ I would not have know what cotton buds were, thanks. Cotton buds around here are what pop out just before the bolls appear and the weevils come ;-)
door
Great - I just wanted a second opinion before I went ahead and did it myself! Haha yah 'Q-Tips' are what they are generally called in at least my area of the US...'Q-Tips' being the name of the company - I guess I could have called them "Cotton Swaps". Haha
door
Yeah cotton swabs is another word we use here :), but looking at Q-Tips on wikipedia, the guy who invented them actually went on to found the company Q-Tip so i guess Q-Tip is the correct wording for them and my "cotton bud" is just a cheap UK imitation ;p
Good luck John, i hope your game works now :)
door
NO. It is not safe to use alcohol on it. It will rust the pins making it useless, use only a scrubbing pad, a soft one and clean them like that, do not blow on them since it will also rust, take apart the cartridge and use counter top cleaner, trust me, i works well, my friend at a retro game shop told me it, and it WORKS. if you tried everything, its just that the board is shorted out and will not work at all, that means it is dead, hoped that helped
door
Carter Setlock, I would like some sources for your claim about alcohol not being safe.
door
2 commentaren meer tonen
Yep, it's fine. It's better than fine, beats blowing in them, as that oxidizes them from the moisture. Just don't use anything strong like acetone, that will eat the plastic!
Score 6
6 opmerkingen:
door
What type of countertop cleaner?
door
door
In the meantime I will submit the following: The usage of Isopropyl Alcohol (99%) is a perfectly valid solution to cleaning any kind of electronics.
door
Hi I have a RTX 3060 graphics card in my rig my daughter managed to spill coffee on it i immediately disconnected all power removed internal battery and proceeded to clean the entire board top to bottom LITTERALLY TOP TO BOTTOM BOTH FKING SODES…. Even removing heat syncs cleaning off them and the thermal paste (replaced it after of course!!) inbetween and under every diode capacitor every single relay followed the leads from start to finish etc etc scrubbed the infrastructure let it dry (takes about 2 seconds since it is miscible with water then will evaporate at room temperature because the kinetic energy at room temperature is enough to overcome attraction of the molecules causing them to disburse into the air rather then stay a liquid. (It sucks water up like a super sponge but unless it’s at like. 70% grade from soaking up moisture it will still evaporate at room temperature almost instantly. Ling story short my 1.5K Board is fine and isopropyl is S+ teir safe for cleaning electronics case closed.
door
1 commentaar meer tonen
Hi folks,
Nintendo Repair Shop repair tech here. While using rubbing alcohol won't hurt your games (unless you absolutely douse them in it), using alcohol and a qtip is really not an effective cleaning method.
Score 3
8 opmerkingen:
- can I come and sell my stuff on your site?
door
Nope, we only sell our own products through our site. Craigslist is a good venue for selling your own stuff though. We have several free repair guides that show how to clean NES, SNES and N64 games the right way. Hopefully you guys find these useful.
door
I'm pretty sure Mayer was trying to subtly criticize you.
door
I saw what he was doing with that. Just felt it was flawed. As far as I can tell, this isn't his site. Not to mention, the information we just put up will help more people with this issue than anything posted in this area thus far. We aren't just peddling goods. We have a real solution that we offer at a very reasonable, competitive price along with free repair guides that we have posted on this site as well as ours, you tube, etc.
door
I like your site it's a good source of information that will help a lot of people and the prices are competitive.. however, you are glorifying the cleaning process way above what is acceptable when people come to this site, they want a quick and easy way of getting their old games to work, thus opening it up and cleaning it with alcohol and a QTip. They dont want to spend $ on something they could do for cents.
door
3 commentaren meer tonen
Here's a video to clean any cartridge with alcohol.
http://youtu.be/Ly4DvUmVkd0
Thank you
Score 1
2 opmerkingen:
Yeah it is the perfect cleaning solution for electronics.
Here a link that show it
thanks
door
How is this different from the answer above;)
door
It's not recommend to use a pencil eraser to clean the contacts of the cartridge. The eraser is abrasive, meaning that if you continue doing this, you'll eventually rub off the gold coating the contacts, making the problem worse. You can use alcohol and a cotton swab to clean the contacts, but NEVER use a pencil eraser.
1 Opmerking:
door
i always used window cleaner such as windex on a cotton swab
seems to work every time the first time
plus not only should the cartridge be cleaned but the console as well
This is the way to clean games: The 1UPcard. Super easy, and designed for cleaning retro game cartridges. The kit comes with 99% isopropyl (rubbing) alcohol and a wide cleaning pad. Find it here:
www.1upcard.com
3 opmerkingen:
door
Carter Setlock, I would like some sources for your claim about alcohol not being safe. In the meantime I will submit the following: The usage of Isopropyl Alcohol (99%) is a perfectly valid solution to cleaning any kind of electronics.
door
Im sorry, Im not a professional, i didnt mean to say like not to use it at all, but i did. I just simply meant like Just be careful to not put too much on and not do it too often, or it could rust the pins.
door
EDIT: Sorry about the wrongful information, i just edited what i know now.
Also Please Beware im a young collector, so i really didnt think when i said that.
Well, its fine to use it but i really dont like to use it but, sometimes i have to. But its not going to hurt to use it a few times, but just be warned there is a possibility of rusting. It really shouldnt go on, but it gets the job done. What i like to do is use a scrubbing pad, a and clean the pins by scrubing it gently. Try not to blow on them too often since again, it could rust from moisture. If it doesnt work, take apart the cartridge and use counter top cleaner, trust me, it works well, my friend at a retro game shop told me it, and it WORKS. if you tried everything, it may be that the board is shorted out and will not work at all, that means it is dead, hoped that helped
3 opmerkingen:
Stop providing misinformation please, what you are saying is complete fiction. I suggest you read up on oxidisation.
door
door
@csetlock rusting only happens to iron, and i'm pretty sure there's no iron in these pins
door
A small amount of Windex OR Isoprophal Alcohol(you want the 91 or 97 % lower has to much water or other liquids mixed in and to high can damage contacts) on a q-tip or on a thing called a one up card(it comes with the alcohol if you buy them)will USUALLY clean them well enough to work. If you use Windex make sure it is BRAND NAME WINDEX or WINDOWLEAN in Canada. cheaper Glass cleaners will have to much water and rust your pins.
If they are extremely dirty you will have to Open the cart up and then using a Brass Polish is best though in a pinch you can use a Pencil eraser though I wouldn't suggest using that every time on the Pins being very careful to only get the polish on the Brass Pins.
There are quite a load of opinions here. Some people will tell you that scrubbing is the best, others will say that rubbing/isopropyl alcohol makes the contacts rust.
I tend to VERY gently rub a pencil eraser on the contacts, as it removes the oxidized layer on the contacts. I then clean them using alcohol and a Q-tip. And for the eraser part, do it only if you have the special nintendo security screwdrivers to unscrew the cartridge, otherwise it is too much of a pain. And if you can unscrew it, alcohol is fine :). Get some 70% or 90% alcohol, or even some 50%. The most concentrated you can find, really.
For female cartridge connectors (the connectors inside the consoles), I usually take an old plastic gift card and I wrap up a piece of fabric around it (make sure the fabric that you choose won't leave any kind of string coming off of it into the connector). Then, I dip it into alcohol and I put it into the console connectors in an in-and-out movement. Be sure not to go diagonally, otherwise you may bend the pins.
As I said at the start, there aren't really any kind of "universal method". Try different methods and think with your head. For instance, never scrub the contacts with anything harsher than an eraser. And even then, I wouldn't use the eraser too often because if there are little dust particles on the eraser you will be scratching you contacts. A couple times is fine, but be reasonnable :).
Have a nice day into the wonderful world of retro gaming !
EDIT: Oh, yeah, and by reading other answers, research the products you are using. I wouldn't use a brass polish, but I haven't researched it. Really research stuff before you use them. And, for the love of god, please, don't you ever, EVER use sprays. They are imprecise and they could cause shorts. Dip your Q-tips into the alcohol or something.
Put in a blank brand new cartridge and run for a couple min. to clean the heads. Then your done.
I used to do that to make them work. Not sure about long term damage, but ID LOSE ALL MY SAVE GAME DATA
haha
Voeg je antwoord toe
John zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 90
Afgelopen 30 dagen: 319
Altijd: 111,508
