Ga door naar hoofdinhoud
De derde iteratie van de 10,1 inch Galaxy Tab-tablet.
Takes forever to charge
Hi my tablet takes an awful long time to charge. If it completely dead, it's takes about 10-12 hours. Why is it doing that and how can it be fixed. It just recently started doing that about 2 months ago. I've also used different chargers in different places. Could I have damaged my tablet by using it while it charges? I can no longer do that because it still dies.
Is dit een goede vraag?
Score 8
6 opmerkingen
Hi Chettona, I have the same problem, my tablet has been charging all night and it still has 30% to go. Ive used different chargers too and I think that's the problem, ive gone back to the original charger which is taking along time to charge my tablet. Not sure what the solution is, however I do plan to remove photos off it at some stage, that might help. Hoping you resolved your tablet charging problems! Leighann
door
I have a 2019 Tab A 10.1 and it constantly keeps giving me "slow charging" notifications, while I typing this it's on charge and it says from 12 % to 100 it will take 5:30 minutes. In the past when it does slow charging it some said it might take 19 hours to 100 %. I got my tab a in October last year and I am using my original charger, I've tried plugging it into some other plugs but still wouldn't help. I have deleted lots of stuff from here, before I used to have 25 GB of storage taken from 32 GB now I've only taken up 16 GB. I have a feeling it is my adapter that's causing problems because when it charges properly its really hot but nowadays it does heat up at all.
door
my tablet uses differ charges lol u guys are fake haha my table heats up a little bit but thats all.
door
@Info Factor
door
I had the same issue but as soon as I went back to using the original Samsung charging brick the problem was resolved.
door
1 commentaar meer tonen
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
I have had this problem before with my tab. The solution for me was to replace the charging wart, which had degraded performance. Are you always charging it from the same location? If so I suggest testing this theory by charging it either with a different wall wart or charging it from a USB3 port on a computer.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
What's a charging wart? 0
door
It is the wall plug with the USB port that you charge most devices with. It should have come with the tablet when you received it.
door
I had a slow-charging problem. I usually plug in my tab to charge while I sleep, and lately, every time I plugged it in, it said "Slow charging - check your connections." I changed the part that plugs into the electric socket and I changed to a different cord - always the same message. So I thought there must be something wrong with my tablet (please, no - it's just out of warranty!) So I tried one last thing - and plugged it in where I usually do my phone, so a different plug-in from the ones I'd tried with, and lo and behold! Normal charging. I'm now going to test all the little plug-in thingy's I have (I kept forgetting them when traveling, so I now have a little pile of them, though I used the one I got with the tablet to routinely charge my tablet.) I think I'll be throwing a few of the cheapies out. Live and learn.
door
The problem is in the wire that you are charging your tab
4some reasons the voltage that are being transfer to ur tab to charge are low
If you have a better wire then maybe ur problem will be fixed
With my best wishes
Anwar
Score 1
1 Opmerking:
I have a loose connection from the cord to where it connects to the tablet. Is this fixable?
door
He's saying use a better charger it may not be enough output to charge it fast... You could always try an ipad "charge block" its the big thick one not the small white one the iphones and watches come with... I had the same problem it could also be a bad outlet in your wall ?? Try it in thr kitchen or bathroom just becareful of water exposure!!
I'm sorry, I have the same problem and feel like calling Samsung as all my phones are. Samsung Notes Tab e a piece of sh..... t... AT&T only had it a year, maybe. I don't have time to call AT&T tech support. Even in my car, Toyota Avalon 2007, 53,000 miles, I am starting to think maybe chargers don't last. Top it off, only use quick chargers. It is 2018, no such thing as obsolete regular, take forever to charge, chargers but cheap a.... as ASURION sent me a refurbished note 5 with the obsolete car charger. How dare them. I am going to do a review on ASURION about their cheap a..... sass... ways. When I have the %#*@ time. ASURION have sent me new phones or a new phone before as I distinctly remember it. Note 3. Same with AT&T, all refurbished and don't trust refurbished and too long story but my 1st Note 5, 64 gb.... on upgrade around 2.5 YRS ago, had fell out of my car and 20 minutes later, I realized I was missing the phone, dropped e 3 miles back towards Kalaheo, high school, why next to the school, because I always use the otterbox, it survived a car running it over, not directly but caught maybe 20% of it. Otterbox was gone. Phone intact, s pen missing, with few scratches around the frame. BUT WORKED A LOT BETTER THAN ALL THE REFURBISHED ONES I HAD and have. Did another warranty claim, as I still didn't do the transfer from phone to phone. Current Note 5 always freezes and says HROME ISN'T RESPONDING, close app, wait, or report... BS as a big delay like NOW. But I needed to know why this fu.... ckin' tab e...... Look, only 49% piece of $@$* (sorry for slang), ridiculous. Said Long story, but I did it..... All about from charging to refurbished VS new.... Thanks GANG
1 Opmerking:
Wow it's always a rip off with these companys
door
Worst tablet ever! tried all
these options and still not working the thing is two weeks old!
Never again will i buy a samsung tablet! apple ipad allll the way!!!
Voeg je antwoord toe
[deleted] zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 111
Altijd: 63,987
