Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
How can I fix my bent ipone 6 plus?
The iPhone doesn't read anything i press on the screen. I took it to an expert to take a look at it, and apparently the iphone has a bent motherboard. every time i want to use it I literally need to slightly bend it for it to read my fingers. Can this be fixed by replacing the rear case? any other suggestions to fix this problem?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
The motherboard bending is not a problem. You can flex those boards a ton and they will still work as promised. What happens is that the Touch IC gets fried in a lot of these cases. Straightening the board only helps it to look better. The Touch IC is still fried and needs to be replaced in order for touch to be recognized again.
Once you get that fixed, you don't have to replace the housing. Its aluminum, you just bend it back into shape. Most of the time you don't even need any tools to do so. If you want, there are tools just for this purpose.
Again, its a chip on your motherboard that is broken. The bend caused it but the bend is not the problem.
Was dit antwoord nuttig?
Score 5
It should.. Wondering why .. The tech said it has a bent motherboard and didn't fix it though...
Score 1
5 opmerkingen:
He worked on the problem but couldn't get it to work. Considering working on it my self
door
Well it's very possible that while "bending" your logic board, it could break. I'm guessing that's why they didn't want to do it. You can try, at your own risk. It might be more advantageous of you to buy a new housing, put he logic board in there, then gently secure your logic board to the new frame with the screws. Be careful while doing this and go slow
Here's parts
iPhone 6 OEM Rear Case
Here's a tear down guide. They're pretty helpful, but sometimes they miss a step. So double check your work, while you're doing it
Demontage van de iPhone 6
If you really want, you could email me imedicminneapolis@hotmail.com I could come up with a quote for you to mail it to me and have it done
door
Deff going to give it a try. If I can't get it to work I will email you. Thank you for your help!
door
Did replacing the housing fix the issue? My phone just started to have the same issue.
door
Tom's right. The housing is cheaply made aluminum. You can bend the housing back, but the touch IC on the board needs to be replaced. It's a pretty complicated repair...
door
The solder joints under the chips may have cracked, just using a new case may not work, you may need to use splints to press the chips or reflow the board.
Score 1
Voeg je antwoord toe
adrianmalda zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 10
Altijd: 18,415
