Ga door naar hoofdinhoud
Vraag afgerond
Anyone know the size of the hex key necessary? [PICS]
Hi, I'm from Sweden and I believe we have different sizes. I have about 5 hex keys the same size but none work. Does anyone know which size I need? I tried ordering a 1/8th inch (?) hex key but it was way too big (suggested at another forum).
I would be so happy. Otherwise, does anyone know how to remove screws without the proper hex key?
Picture below.
https://drive.google.com/file/d/0Bz1Mzil...
Is dit een goede vraag?
1 Opmerking
this is not a hex key it is a torx
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
That looks like a security torx screw (see if there is a pin in the middle of it). Take a look at these: http://www.ebay.com/itm/like/23116976979...
Here is the Service Manual on your machine: http://www.manualslib.com/manual/438779/...
Was dit antwoord nuttig?
Score 5
3 opmerkingen:
Thanks! Will look into it.
door
Success! I bought a starter kit of torx keys :) Let's see if I manage to fix the printer.
door
I have no idea if you can actually fix it but you will be able to get into it.
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 904
