Ga door naar hoofdinhoud
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 Vragen Bekijk alle
My 360 wont turn on how do I fix it?
About a week ago I was unplugging my usb keyboard from my 360 and when I pulled it out the black piece inside the usb port broke off and came out now the usb port is useless.I thought it would be ok but after I turned it off I tried turning it back on and it would give me rings of light or anything. And my power supply is fine so any ideas?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
When this plug came out you probably shorted the connector. Turning it own could of destroyed the xbox. All my not be lost though. Open it up and get to the board that has this connector on it. Get out a soldering iron and remove it carefully then see if the xbox comes on. It probably will since shorts on the board can trip the safety devices in the power supply.
Was dit antwoord nuttig?
Score 2
Move the pins in the usb port that you broke so that they arnt touching themselves or anything else and that should get your xbox up and running again. when the pins touch they just short eachother out and wont allow your xbox to turn on.
Was this answer helpful?YESNO
SCORE
2
Rep: 37
POSTED: FEBRUARY 8, 2013 OPTIONS
I P
L
D E
O
N S
' E
T
H
K E
N L
O P
W
M
S E
O
Voeg je antwoord toe
Cody zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 6,178
