Ga door naar hoofdinhoud
De Xperia Z1 Compact is Sony's premium cameratelefoon. Hij is vergelijkbaar met het Xperia Z1-model, maar kleiner en goedkoper. Het belangrijkste kenmerk is een 20,7-megapixel sensor. Bij de release waren de beschikbare kleuren wit, zwart, roze en limoengroen. Dit apparaat kan worden geïdentificeerd aan de hand van het modelnummer (D5503)
Screen not working after replacement
Hello I have Xperia Z1 Compact with a broken screen. I have ordered a replacement screen from ebay. When I connect the screen to the phone and turn it on, nothing happens. I know that the phone works because I hear boot up sound. Also when I press unlock button and then volume up/down keys I can hear the volume change sound. If we assume that the replacement screen is working, what could be wrong with the phone? Is there anything I could do to fix it?
Is dit een goede vraag?
Score 1
1 Opmerking
I have a similar problem, i tested the new screen and was satisfactory, however after installing it with the gasket it failed to fire up
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
The LCD ribbon cable could have been damaged during installation. Make sure the lcd connector is connected prperly. You might have a defective part, eBay parts are not always the best choice....
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for the answer. Unless the ribbon was already damaged I doubt I damaged it. Connector is easy to access and I was gentle. I was wondering what chances are there that there is something wrong with the phone itself. For example that metal panel below the display (is that heatsink?) seems a bit detached now. Could a connector itself be a bit detached from the board?
door
Voeg je antwoord toe
Ivan Savu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 1,357
