Ga door naar hoofdinhoud
The Brother MFC-240C is an all-in-one color inkjet printer.
29 Vragen Bekijk alle
How so I find out about Troubleshooting for message Print Unable 50?
I had a paper jam. After clearing out the paper, I am getting a message that says Print Unable 50- Refer to Troubleshooting chapter in Owner's Manual. I cannot find my Manual. Can you tell me what to do?
Is dit een goede vraag?
Score 2
4 opmerkingen
print paper in blank
door
troubleshooting for massage print unable 50
door
how so i find about troubleshooting for massage print unable 50 ?
door
troubleshooting for massage print unable error 48 mfc j 200
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi,
Here is a link to the User Guide for your printer.
https://www.brother-usa.com/modeldocumen...
Found this information which may (stress only may) be the cause of your error message:
This error is usually caused by the Carriage Encoder Strip being dislodged from the sensor mounted on the Print Head/Carriage Assembly. The upper case assembly will need to be opened, and the encoder strip will need to be put back into place. Its also possible that the error can also be caused by grease or fingerprints on the Encoder Strip, even if it is still in place
Here is a link to the service manual for your printer (as well as other similar Brother printers). Scroll to Ch.6-48 for information regarding the CR encoder strip.
http://ftp.brother.co.il/fax/MFC845.pdf
If it is all a bit daunting, suggest you either contact Brother service or a professional printer repair service and ask for a quote.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Louise Parker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 10
Altijd: 4,532
