Ga door naar hoofdinhoud
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
53 Vragen Bekijk alle
Where is the fuel pump relay?
I need more specific answer for 1998 Mazda 626 four cylinder. Where is the fuel pump relay?
Is it the relay marked EGI or the Circuit Relay?
Is dit een goede vraag?
Score 1
1 Opmerking
What’s the one in the middle on the bottom of the picture??
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@yetbo check the fuse box in the engine compartment. There are a few varieties, white relay (green relay) same location. Sometimes labeled as EGI and sometimes as Circuit relay. Location is the same.
. You can find great information on here
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
the second pic is wrong
door
the first pic has a jumper running to the fuel pump
door
Voeg je antwoord toe
boyett zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 138
Altijd: 15,217
