Ga door naar hoofdinhoud
De Microsoft Surface RT (model 1516) is de eerste tablet die door Microsoft is uitgegeven. De tablet werkt op Windows RT, deze versie is speciaal ontworpen om te werken op een tablet. Om deze tablet te repareren heb je schroevendraaiers nodig, alsook gereedschap om hem te openen.
128 Vragen Bekijk alle
Will not turn on. How do you determine what the issue is?
Windows RT tablet will not turn on. Power light is on charger. Can this be repaired? Microsoft says no. How do you determine if it is a battery issue vs hardware or software?
Update (01/16/2016)
The power light is on at the charger connection to the tablet. The tablet is over 2 years old. How long do the batteries normally last? If I open it up I do not understand what to do next?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Is there any indication on the tablet that the charger is connected? Without power either external or internal (battery may be to low to start tab) nothing will work. That is the first step - determine if power is reaching the board, which means opening it up and progressing from there. It may be simple like a faulty power socket, but then again it may not be that easy and without schematics, tools etc it will be very difficult.
It may be better to try and sell it as "faulty, good for parts" whether as individual parts or complete is your choice, (here is a link to show you how to dismantle it Microsoft Surface Teardown ) to try and recoup some of the cost
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Hi, Bruce
Have you tried solutions 1 & 2 from this link?
https://www.microsoft.com/surface/en-us/...
door
Voeg je antwoord toe
Bruce Doughty zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 163
