Ga door naar hoofdinhoud
The Nissan Xterra is an SUV that was manufactured and marketed by Nissan Motors across two generations, utilizing its Nissan F-Alpha platform shared with the Nissan Frontier pickup.
20 Vragen Bekijk alle
What if my clutch pedal switch is bad
2001 Nissan Xterra. what if the clutch pedal switch is bad
Is dit een goede vraag?
Score -1
1 Opmerking:
Ashley Woody clutch pedal switch? Not sure what you are referring to. What does or does your clutch not do? Give us a better idea of what your question is about.
door
Voeg een opmerking toe
1 Antwoord
Usually the only function of a clutch pedal switch is to make sure you have a foot on the clutch when starting the engine.
There are potentially 2 failure modes:
1 you can't engage the starter even if you do step on the clutch pedal
2 you no longer have to step on the clutch to engage the starter
Was dit antwoord nuttig?
Voeg je antwoord toe
Ashley Woody zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 253
