Ga door naar hoofdinhoud
De Visual Land Prestige 10 is een tablet met internetverbinding van Visual Land INC. Deze apparaatpagina en de daaropvolgende reparatiehandleidingen laten zien hoe u de onderdelen van het apparaat kunt verwijderen en vervangen.
cant charge my table
I cant charge my table, do your company sell one that will fit my device
Is dit een goede vraag?
Score 9
10 opmerkingen
Mine will not charge, it's only 2 months old
door
Also when I try to turn it on a battery symbol with a triangle in it appears
door
I have the exact problem, is there a solution? Besides buying a new one.
door
I am also having this problem, getting very frustrating!
door
Mine and my daughters will not turn on either and both are only 3 months old!
door
5 commentaren meer tonen
Voeg een opmerking toe
6 Antwoorden
Filteren op:
Het nuttigste antwoord
the recver end of the charger is pushed back in not allowing the power cable to make contack . it needs to be pused back in place to make contack agend.
Was dit antwoord nuttig?
Score 5
4 opmerkingen:
How do you pull the receiver end back out
door
How do you pull the charger piece back because mine is pushed back
door
How do I pull back out or where can I send for repair
door
do you have to open in up
door
My tablet will not charge. The end of the charger will not connect to tablet?
Score 1
1 Opmerking:
I am having the same problem! What is the answer?
door
well do you have one
I would like to have this uniy replaced there is something wrong this is pnly about the twenty time this has happened i am tired of this.
It is not turn on at all and not change
tablet dose not response or turn on or off
1 Opmerking:
My charger wobbles when it is connected to the tablet and the charger end does not go in completely. It won't charge. What gives?
door
Voeg je antwoord toe
kathleen pruitt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 33
Altijd: 1,746
