name not showing in the Bluetooth connection.
Bluetooth worked fine when we connected it to the first device and when we tried connecting it to another one it didn't appear in the Bluetooth connection.
Is dit een goede vraag?
Hi,
You have to un-pair (or disconnect ) the Flip from the first device.
Press the Start button on the JBL Flip, it will make a warning beep and turn on. The start button will glow blue.
Press the '+' and '-' buttons together, and press the 'Bluetooth' button on the JBL Flip, and keep pressed until the Bluetooth button starts blinking blue. Now the JBL Flip is in pairing mode and can be discovered by the new device.
Was dit antwoord nuttig?
I tied with this. but it is not working for me
I went to Apple Store. They tested my new I-phone. It worked perfect. ATT tested my modem. Running perfect. Neither my JBL Flip nor my Altec Lansing will connect with the Bluetooth. The tech at Apple suggested that the cue "forget this network" might clear up the problem.. It didn't!! I re-entered my passwords, nothing works. Both speaker systems worked great until my Apple stolen phone was replaced. All the lights blink on the speakers in the proper sequence but no music.
Still won't work on either device. iOS 11.2. Someone forgot to test this iOs upgrade.
It worked. Thanks
This did not work for my Android 7
Turn on jbl go, led will starts blinking, now hold on Bluetooth button and volume “-“ button same time. After some time led button stops glowing it means now your Bluetooth is reset successfully. This works for me.
Mine has a Bluetooth button next to the volume button, and I needed to push that one instead. Hope this helps someone.
Awesome! Thank you. This finally worked!
I just held down the Bluetooth button by the volume down button until power button blinking blue- looked on iPhone, it was there, hit connect and connection successful
I held down pairing button and volume minus button after 10-15 it powered off and won’t come back on unless connected to power cord. Any advice?
I held down jbl+ connect button and volume minus and plus button after 10-15 it powered off and won’t come back on unless connected to power cord. Any advice?
Press the “+“ and the phone buttons at the same time while JBL is on. It will then shut down. Restart, Pair will be successful.
Han yi, thanks it worked! I pressed the + and the phone button then it connected now to my android! May i know your fb name? I wanna be friends with you! Again thank you!!
Good job mate it worked for me with iOS. The Clip needs to have the Bluetooth reset to re-pair successfully.
This is what works. Thank you. Phone and +
Thanks alot buddy it worked.
This worked, after 2 days trying everything else. Nice one.
I tried all the fixes and no results until I read bnmwilliams response! Geez.. the bluetooth button was right there… next to the -
Not sure if all the other remedies cleared the way but finally it worked.
Thanks!
Just got my old JBL Flip connected to iPhone on iOS 14.3. Turned on and red light came on. Pressed fir 3 seconds and button flashed blue. Could not see JBL on Bluetooth list on iPhone. Eventually pressing the + and phone button together got the light to flash red/blue and JBL appeared on Bluetooth list. Selected and paired successfully. I forgot how good the sound is.
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 95
Afgelopen 30 dagen: 388
Altijd: 347,426
14 opmerkingen
How do you connect Google home to a job charge 3
door Marianne Cordova-Breen
Hope this link https://youtu.be/bHTyy8id6WA helps you.
door Subba Reddy Gowru
Will it work for a Coolpad 3632A phone
door Akayla Strong
Still isn’t recognised by the phone
door maryspink7
How do you put the name in the phone
door Norman Pinson
9 commentaren meer tonen
