Ga door naar hoofdinhoud
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 Vragen Bekijk alle
verizon or sprint replacement micro usb port
whats the difference of whether i buy a sprint replacement charging port or a verizon replacement charging port? I have an at&t htc one m8 and they dont have one so i was wondering if it would make a difference if i used the sprint or verzion port.
Is dit een goede vraag?
1 Opmerking
My local phone / computer repair shop just confirmed for me that the solder used to connect the micro USB port to the motherboard is a higher temperature solder than what's used for the other components, intentionally to make it darn hard (nearly impossible) to replace this “wear item” in order to sell more phones.
This shop won't even attempted this repair any longer after several failed attempts and they consider themselves experts at micro soldering.
Sucks that phone companies have all figured out this dirty little bit of truth (that we are not surgically precise in our connecting and disconnecting our cords) and so they are getting away with building in and selling planned failure.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Trevor, no it will not make a difference.
Was dit antwoord nuttig?
Score 1
The verizon usb port is the same as the at&t , but they are different from others like sprint. This blog has listed their differences: http://www.witrigs.com/blog/htc-one-m8-a... .
The verizon / at&t m8 charging port is here: http://www.witrigs.com/oem-charging-port...
The sprint/other variant m8 charging port is here: http://www.witrigs.com/oem-charging-port...
Voeg je antwoord toe
Trevor zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,346
