Ga door naar hoofdinhoud
The TH (turbo-hydramatic) 700R4 was developed for use after 1982 in GMC and Chevrolet cars and trucks.
doesn't always catch 3rd when shifting from 2nd to third
when my son leave, his truck shifts fine 1st to second, but when it comes time for 3rd it acts like it finds neutral, he lets the rpm drop down and it hooks up to 3rd fine and goes on after that. his fluild is clean and smells alright, any ideal what's up and if it could be an adjustment.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Tough one. This may require an adjustment on the TV cable. However if the TV cable is maladjusted, that could cause damage to the transmission.
You can find the directions to adjusting the cable here.
Good luck, I wound up having to replace my tranny. If you get a used one do yourself a favor and rebuild it before you put it in and adjust the TV cable before you drive it anywhere.
Regards,
Frank
Was dit antwoord nuttig?
Score 3
700r is a no good transmission, if u can just upgrade to the 4l60
Score 1
1 Opmerking:
The 700R4 is actually the same transmission as the 4L60, GM just changed the name in 1990. 4L60 stands for 4-speed Longitudinal 6,000 lb gross vehicle weight rating (GVWR).
door
Dirty transmission fuel could cause the transmission’s gears or springs in the governor to delay shifts. Most websites recommend just having the transmission serviced regularly. Interesting that your problem is between second and third gears because one of the common problems with this transmission is slipping between the 3rd and 4th gears. Overheating can weaken the transmission’s clutch pack disks, causing the ends to shear off and causing a serious problem.
Voeg je antwoord toe
dave zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 5,186
