Ga door naar hoofdinhoud
Vraag afgerond
Remove HDMI- board from Onkyo TX-NR609
Hi! Trying to remove the HDMI-board from my receiver and have removed all the cable connectors. But the board is mounted on another board and I can't separate them. How do I do it?
Link to a (bad) picture of the connection:
http://sv.tinypic.com/r/15d48de/9
Is dit een goede vraag?
1 Opmerking
Thank you, that really helped! Was just to careful, once a little bit of force was used, it came right of! Thanks again! :)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sofie it's kind of hard to see on the image but those are just some very tied connectors. For as long as you removed all the screws from the HDMI board to the chassis and removed all the cables, you should just have to pull them apart. Check the video from here at the 02:52 mark.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks, that really helped, I was just worried about the amount of force that was needed. ;) Since you seem to know Onkyo products, I found a connector in there I have not seen before, are you familiar with this?
http://sv.tinypic.com/r/ddi07r/9
Especially with how to release it. :)
door
Thank you, that really helped! Just a little more force than I thought, then it just snapped right of! :)
door
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 5,750
