Ga door naar hoofdinhoud
Repair guides for the Samsung Galaxy Tab A series of tablets. Released in 2015.
470 Vragen Bekijk alle
I can not get my earphones to work! ( Galaxy Tab A)
So I can not get my earphones to work, I can't figure it out or I'm just that stupid. LOL And yes they were plugged in , LOL And the earphones work worked great with my other tablet.
So if you might be able to help, that would be great.
Thank You, Terry T.
Is dit een goede vraag?
2 opmerkingen
I try to put a headphone jack in my samsung galaxy tab a but it won't work
door
I tried everything and my headphones won't work but they work in my phone
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
First, do the tab's speakers work when you do not have the earphones plugged in? If not check the sound settings.
I know you said earphones work in another device. Just to prove things try a different set of earphones in your tab. If they don't work then your earphone socket is either faulty or has become disconnected off the board.
You could try just very gently moving the plug side to side or up and down while it is in the socket and see if you get any sound. If so it possibly proves a loose connection.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Thank you so much! OK now have you ever sent any to be fixed? I have a problem with not being able to take it back a getting another one. I hate buying something just to find out that something not right and the inconvenience.
Jayeff ,
Thank you! I will try it again after feeding the animals
WISH ME LUCK, LOL
door
Hi Terry,
Under Settings > Accessibility > Hearing there are two setting you may wish to check.
Left/right sound balance: Set the device to adjust the sound balance when using a headset.
– Mono audio: Set the device to switch the sound output from stereo to mono when a headset is connected. Here is a link to the user guide scroll to p.95 http://downloadcenter.samsung.com/conten...
door
TRY USING USB TYPE C PLUG TO 3.5mm EAR PHONE ADAPTER (£4) IN THE CHARGING PORT OF THE TABLET. IT WORKS FOR ME, ACCEPT THE SELF CONFIGURATION PROMPT WHEN FIRST USING IT.
Keith
door
Voeg je antwoord toe
Terry zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 52
Altijd: 2,752
