Ga door naar hoofdinhoud
Elektrische Thomas de Stoomlocomotief-trein met rails.
Where to charge the train
Where do I charge the train, If I go under the seat which plug do I plug the charger to, so the train can work I have no idea what I am doing.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Apparently it's at the back of the train. The charger, hopefully you have it, is an unusual shape, and there shouldn't be any mistaking where it goes. Sorry I couldn't be more help
Was dit antwoord nuttig?
Score 2
1 Opmerking:
thanks a lot for your answer
door
You must remove the two Phillips screws on the black plastic seat. Remove the seat. Unplug the 2 prong hard plastic connector that goes to the 6volt battery. Connect the charger directly to the 2 prong connector that goes to the battery. Wait 6 hrs and then unplug the charger. Reconnect the connector that goes to the motor back to the battery. Replace the seat and tighten the 2 screws down. Enjoy!
Voeg je antwoord toe
Constance Briscoe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 71
Altijd: 7,103
