Ga door naar hoofdinhoud
Aangekondigd - november 2014 De Samsung Galaxy Core Prime (G360, G361) wordt aangedreven door een quad-core processor van 1,3 GHz en wordt geleverd met 1 GB RAM. De telefoon heeft 8 GB aan interne opslag die via een microSD-kaart kan worden uitgebreid tot 64 GB.
Phone is not turning on
I was browsing through net then suddenly my touchpad stopped working. Display was clear though but touchpad was not working. Then i googled about it and came to know that i have to remove the battery and press the power button for 60seconds and then place the battery back and switch it on. But after placing the battery back, The phone is not getting switched on
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
What was the battery percentage before it turned off? Does your battery drain fast or have you noticed anything like this before?
There might be a chance you just need a new battery. If you have owned that phone for awhile and it is the original battery - batteries eventually just need to be replaced over time. I would test to see if that is the issue.
I hope that helps.
Was dit antwoord nuttig?
1 Opmerking:
No the battery was like 25%, and like i said i switched it off. and then pressed power button for 60secs and then tried starting it.
door
Voeg je antwoord toe
Gourav Agarwal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 1,852
