Ga door naar hoofdinhoud
De Trio Stealth G4, gefabriceerd door Mach Speed Technologies, is een touch screen tablet met een 7,85” HD-scherm. Het apparaat beschikt over wifi, Bluetooth en Google Play-mogelijkheden, met functies zoals een quad-core processor en camera's vooraan en achteraan.
Screen Cracked On The Tablet
Hi, I took my tablet to New York with me and didn't use it for the whole ride was going to though so I wouldn't be bored then on the next day, I open my case to my tablet to see that it was cracked. I did no physical damage to it. I thought the case was suppose to protect the tablet. Anyway, I have important information on it and I can't reset it because of the crack on my tablet. What should I do?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
What you need is a new digitizer screen for your tablet, while I have one here, I do not know how locall I am to you. I am in Michigan. Check a local company first for repairs. I charge twenty dollars for the screen and thirty dollars labor. Reach me at drslawinski2@gmail.com.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
What do I type in for the correct search local parts and service
door
You can do what David Slawinski said and pay someone to repair it for you, but you can also repair it yourself for much cheaper :) This video will show you how
https://www.youtube.com/watch?v=ClSOlEdr...
You will need a heat gun or hairdryer the part is below it comes with all the other tools you need
For 7.85 inch: https://www.amazon.com/Atabletparts-Trio...
For 7 inch: https://www.amazon.com/Screen-Digitizer-...
An old credit card can be helpful for prying the old glass off. If you think you will want to repair stuff in the future I would suggest a toolkit, this is the one I have: https://www.amazon.com/dp/B00VJYWRKW?ref...
It is really nice, I fixit also makes some really good tool sets like this one: Essential Electronics Toolkit
Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C). Afbeelding
Product
Heat Gun
$29.99
Our gateway kit to electronics repair, perfectly sized and priced for essential electronics repair. Afbeelding
Product
$29.95
Score 1
Voeg je antwoord toe
Stephane Caldwell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 1,004
