Is it the baseband?
Hi ,
I have an iPhone 5 that I made fell for about 50cm . I found that the battery was disconnected and it was there NAND ERROR which I repaired by changing the screen ( the digitizer not work) Well the starts and everything works ... I also had a problem at the rear camera (2 spots that would not be removed even after doing a little cleaning so I ended up changed. after that ! the iPhone works but it gets stuck on "Searching ..." ( And when I remove the SIM it not show me the message no SIM Installed ) I tried everything ( airplane mode , reset the iPhone, remove the SIM ... ) I could not activate the iPhone. and I finally restore via iTunes that shows me the error 47. So I hope you can help me and thank you in advance.
-------- PS : I read that this was the baseband which was ruined , but I do not think the repairer have made a mistake !
Is dit een goede vraag?
