Ga door naar hoofdinhoud
A 23-inch touchscreen All-in-One powerhouse PC put out by HP that is intended for business and home uses. The HP product number for this device is: #K1K41UT#ABA
6 Vragen Bekijk alle
Why do my keyboard and mouse run out of battery so fast?
They seem to turn off after a very short period of being on. Replacing the batteries only makes them work for a little while. After a couple uses, they won't turn on at all. No lights will come on and they seem to malfunction sometimes when "low" on batteries.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Make sure to turn your mouse and keyboard OFF when not in use for extended periods of time. Also, try reducing the distance between your keyboard/mouse and the computer itself. Reducing the signal length will help preserve the battery. Check out this troubleshooting guide for more info: HP EliteOne 800 G1 Troubleshooting
Was dit antwoord nuttig?
Voeg je antwoord toe
Kyle Koivuniemi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 7
Altijd: 172
