Why is Huawei Y600 taking too long (30 minutes) to start?
When I switch on the phone, the Huawei flower comes on and it takes almost 30 minutes before it starts. Please help.
Is dit een goede vraag?
Hi,
Firstly, When you phone has finally started go to this link and download, install and run Malwarebytes Anti-Malware Mobile.
https://play.google.com/store/apps/detai...
also if you have no anti virus installed you may wish to download, install and run Avast Mobile Security and Anti Virus.
If they both pass with no problems reported, then back up all your data. Scroll to p53 in this link
https://www.manualowl.com/m/Huawei/Ascen...
and perform a hard reset to rectify your problem.
http://www.hard-reset.com/huawei-ascend-...
Warning:You will lose all your data and settings when you perform a hard reset that is why it is important to back up your data
Was dit antwoord nuttig?
My Dear Friend this not a answer for this Problem..How he can reset..he is telling that Huawei flower hang..to follow your steps must on phone first..
Hi, @alexverlinmelsa ,
There are 2 ways to reset the phone.
One method is to use the menus in the phone, I agree that if it hangs on start that this method won't work.
The second method is to use the power and volume buttons in combination as shown in the link above on how to perform a hard reset. This method starts from the phone in an off condition and uses different software setup to get to a different menu screen which allows to reset the phone by erasing the original software installation and replacing it with an untouched copy (by the user) that is stored in the phone. It usually works but it also erases any user data and downloaded apps as described above.
Also the original answer above was for a problem where it was stated that it "eventually started after 30 minutes" and then he did have access. Therefore the answer to install A/V app and anti Malware app and to perform a reset via the phone menus is relevant.
Well, android phone will slow by the passing of the time. normally, an android phone will last few years. How long have you been used this phone?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,145
1 Opmerking
My Huawei y6 was not working well slowly and said system not working, how to fix it
door Charlz wyrenz
