Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Touch screen works briefly then freezes
Hi,
I have an iPhone 6 and the touchscreen will freeze randomly. Sometimes I have to wait five minutes from start up for it to respond. Sometimes it works straight away but only for a few minutes. Sometimes it'll work for twenty minutes. There is no rhyme or reason to it freezing.
Here's what I've tried,
1. Soft resets - didn't help.
2. Factory reset and set up as new device- didn't help
3. Fitting x 3 new known working screens - didn't help
4. Cleaning the connectors with iso alcohol - didnt help
5. Updating software which went fine (no error codes) - didn't help.
Probably helps to mention I've switched the motherboard out of a damaged housing to another genuine housing. I own a small repair business and can strip most parts almost blindfolded.
I can't see any physical damage to the board and if the mobo touch connector were damaged the rogue white lines would appear.
Any advice would be appreciated.
Thanks in advance.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Solved.......School boy error, wrong screws in wrong holes for connector shield causing visible trace damage to centre and bottom right screw holes, that'll teach me for working late and removing both motherboards at the same time. Anyone know a mobo repair specialist in the UK?
Update.....After consulting the legend that is Jessa @iPad rehab it seems it's a touch ic failure which is common with the iPhone 6. The trace part of the mobo is under a metal shield so unlikely that's the cause.
Was dit antwoord nuttig?
2 opmerkingen:
Sorry if it's obvious but with "touch ic" do you mean touch ID? I have this problem aswell with an ip6 and it doesn't freeze as long as the screen isn't fitted in place (sitting loosely on top without connector shield)
door
Nope, touch ic is a chip on the motherboard.
door
Het nuttigste antwoord
If it weren't for the setting up as a new device, I'd say it has too much memory stored
Score 1
1 Opmerking:
I'm going to return the motherboard to original housing tomorrow, although I can't see it will help. Original housing is 16GB (same as mobo) and the other is 128GB but I'm pretty sure they are identical.
Thanks for your comment.
door
Had the same problem and solved this by unscrewing the middle screw of the connector shield. Any ideas as to why this works?
1 Opmerking:
That didn't work for me. I completely removed the shield and still no joy. Your problem could be caused by mixing up the screws for the connector shield or possibly slightly out of place/loose push connectors. Could possibly also be a sign the ic chip is on its way out.
door
I have tried all.of that myself and nothing works. What is wrong is your integrated chip that controls your touch. Called the touch ic. It is basically the brains brains of your touch. Whatever you do Whatever you do not bang your phone against something hard or drop it so it works for a while. By me doing that it just caused my network ic to give up. Now im stuck without touch or network. Before i could call or text using siri. Take.it to a repair shop immediately because then more internal problems will be caused which means less possibility of fixing the phone! Feel free to watch the video below. It is explained more thoroughly by my experience!
https://youtu.be/3Nd4mDkK6Sw
1 Opmerking:
Thanks, for your reply. The fault was established two and half years ago before touch iC disease was a well known issue. Apple replaced the device for me.
door
Voeg je antwoord toe
James zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 3,167
