Ga door naar hoofdinhoud
Reparatiehandleidingen voor grafische kaarten en videokaarten.
111 Vragen Bekijk alle
My NVIDIA G card sentinel shows I have power issue
"To protect your hardware from potential damage or causing a potential system lockup, the graphics processor has lowered its performance to a level that allows continued safe operations."
this was shown when i turn on my PC today. tried reconnecting all the cables but still fail to fix it.
is it about my power supply box problem?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I am guessing your power supply doesn't have enough power for the fan on the video card. You may need a power supply upgrade. To be on the safe side if it used to work try cleaning the graphics card for maximum cooling. If the card is clean I would try a power supply first (less expensive). If the cleaning and power supply replacement don't do it you may have problems with the graphics card but that would be the last thing I replaced. Ralph
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
thank for the tips. will try it tomorow morning and reply on the results as soon as possible.
door
Voeg je antwoord toe
anthony zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 2,921
