What does water under pressure message mean?
Warning says "water under pressure" perform needle maintenance. We took it apart as the book directed and rinsed out. Warning still comes up.
Please help. Machine is less than 1 month old. Purchased at Walmart in [location removed]
Is dit een goede vraag?
91 opmerkingen
This is unbelievable I am having the exact same problem! I gave up my Bunn coffee pot that I have had for many many years because that is all I will buy for this Keurig! like everyone else I have had it for 1 month! I appreciate the directions how to fix this problem but again it is one month old! Not too sure if I'm going to keep it or return it. I will probably end up going back to my Bunn coffee pot. Because no matter what you think I will have to deal with this problem again in about four weeks and it's not a pretty sight first thing in the morning
door Tammy Cates
Same problem, followed the directions, called support, they are sending a new system, hopefully I get it within the next 3 days as promised.
door Len Dubois
This is now my second one and same issue! They resent me a new one because of the warranty and I had the same issue. I bought a cheap one two year ago at big lots and it lasted two years, both of these have not lasted more then two weeks! I've bought only keurig approved kcups!
door Carlie Mohr
All you have to do is use the needle cleaning pod to release the pressure in the needle. Grounds get stuck in there and it pulls them out. 1 minute fix.
door Veronica G
I just had this happen, tried the needle cleaning maintenance like 10 times, but it didn't work. They are sending a replacement.
door jimgerran
86 commentaren meer tonen
