Ga door naar hoofdinhoud
The Stealth-G4X is an Android tablet that was released by Mach Speed in 2014. It has a 7.85 inch screen and operates with Android Kit Kat 4.4. It has a resolution of 1024x768 and a Cortex A7 processor with speeds of 1.50 GHz.
Why would the camera on this tablet not work?
What would cause the camera of this tablet to not take pictures and stop working.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
There are various causes for your camera to malfunction on the Trio Stealth-G4X. These include low battery, a dirty lens, not enough storage space, or a damaged camera.
If your tablet has a low battery percentage, your camera application may refuse to open or take pictures. Try charging your tablet and attempting to use the camera at a later time.
If your tablet seems to be taking blurry or dark pictures, your lens might be dirty. Gently wipe the lens with a clean, soft cloth.
Your tablet may refuse to take photographs because your storage is at full capacity. Be sure to check and see if your storage is full in the settings. If this is the case, you should delete some of the existing photos on the device or use a MicroSD card for additional storage.
Your camera may be unresponsive because it is damaged. If this is the case, it will need to be replaced.
For additional help and answers to similar questions, please visit the Trio Stealth-G4X troubleshooting page.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I try to download camera but it still not working
door
Voeg je antwoord toe
Riley Briggs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 622
