Ga door naar hoofdinhoud
Vraag afgerond
Installing New HD cant load OS
Hello,
I have a Macbook pro that started developing HD problems, Last week it the HD failed.
I was able to get it into target mode to recover data. I tried first to reformat and reinstall Lion, It would run the installer count down and then when it got to 0 time remaining start over. I decided that it was toast and purchased a new hd and installed it. I tried to install the os and using the dvd installers and would try to boot to dvd but would kick it out. I tried to recover from last backup it would and then not see the hd.
It will boot to external usb hd but not let me install lion. I tried using the orginal dvd's but would start and then have boot errors writing to the new hd. I am cloneing my current macbook to see if it will take the cone this is in the process so i cannot report if i will be able to do the reverse. I have tried every trick in my bag to get this new hd to boot the computer but i either get a blank gray screen or blinking ? mark. One other thing when i do try to boot to it i sometimes here 3 ticks right after the cimes with 3 lights on the front near the latch or it boots to external hd. Please help, i am leaning toward that the cable might not be able to handle this hd and not the logic board because it boots to dvd (when it dosnt kick it our) or to the usb hd.
Is dit een goede vraag?
3 opmerkingen
I have reseating the ram twice as well as checking the conections to the new HD twice. I know that 2 g of is the min for this computer and was thinking of upgrading but wanted to install OS with the ram that came with with machine when i bought it new. I am using carbon copy to restore the HD that is inside using a usb HD that will start up and run the computer although rather slow. So my reasoning was that the newer drive is having problems with the old cable.
door
I am just trying to confirm my best guess that the cable might not be sufficient to run the new HD and since it runs from a usb drive with the same software version, I can see the new hd and clone to the new hd that the problem is the cable
door
Here is the spec sheet for your drive: Seagate - Momentus. Jump down to section: 4.2 Configuring the drive Do you have a jumper in place? You'll need to put in on. Then reformat the drive and re-install the OS. That should fix the issue.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I would replace the Hard Drive/ IR cable. The cable failing on the 17" model is unusual. The beeps usually indicates a RAM issue, try reseating it. This may also be an issue with the new drives speed. Is it backward compatible? Please give us the last four figures of your serial number so we know your exact machine.
UPDATE 10/26
Standard Hard Drive: 160 GB (5400 RPM) Int. HD Interface: Serial ATA (1.5 Gb/s)
Apple MacBook Pro "Core 2 Duo" 2.6 17" (SR) Specs
Identifiers: Mid/Late 2007, 2.4GHz* - BTO/CTO - MacBookPro3,1 - A1229 - 2137
Is the new drive backward compatible to 1.5 GB/s? If you don't know, please give us the make and model number of the new drive
Was dit antwoord nuttig?
Score 2
7 opmerkingen:
yxa9 are the last 4 I am currently sending the clone to the internal HD and it runs ok on external HD although slow
door
Seagate Momentus 7200 750 GB 7200RPM SATA 3Gb/s 16 MB Cache 2.5 Inch Internal Notebook Hard Drive -Bare Drive ST9750420AS
door
First, lets see if the systems firmware is up to date. Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers. Generally, you need to match the systems SATA ports data rate.
door
It shows to be backward compatible to 1.5 GB/s. 750GB Seagate Momentus 2.5-inch 9.5mm SATA 3.0Gb/s 7200RPM Hard Drive with 16MB Cache
750GB Seagate Momentus 2.5-inch 9.5mm SATA 3.0Gb/s (1.5Gb/s backwards compatible) 7200RPM Hard Drive with 16MB Cache.
door
model identifier: MacBookPro 3.1
Boot Rom version MBP31.0070B07
SMC VERSION (
door
2 commentaren meer tonen
The cord could be part of the mess. Ive encountered this on a smaller level. In my case it was the memory was maxed. The other time it was 39 vireses and 2 trojans. In the last the pc was junk, the first was a hard start. Power off. Hold vol. - and power on. Conferm prompts. Done. I hope this helps.
Score -3
1 Opmerking:
@EC Se - First this is a Mac not a Windows PC. While viruses are possible they are just not that likely be on a Mac. The symptoms this persons system is having has nothing to do with viruses or trojans. You really need to do some reading before answering. We want people to be involved but throwing out junk is not the aim here. Yes, people do make an error or two but your way off in left field!
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 289
