Ga door naar hoofdinhoud
The OptiPlex 755 is an energy-efficient desktop computer designed for businesses. It was released in mid 2007.
26 Vragen Bekijk alle
Adding a video card
What video cards can I use to upgrade my system
Is dit een goede vraag?
Score 8
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
mrmac4, your Dell has a PCI Express x16 connector slot which could be used for a video card upgrade. No issues with that at all since a PCI Express graphics card will override the integrated video controller.
Was dit antwoord nuttig?
Score 4
Dell has annoying proprietary motherboards, but this one still allows small form factor PCI-e GPU’s.
If you can explain what you want to use the GPU for, we can select a fitting one for you.
In short:
For HD video playback, an AMD HD4550 should be fine. For light gaming a Nvidia 750 is about the max I would trust the crappy power supply in those things with.
Score 2
1 Opmerking:
what about the gt1030?
door
Does it have a small bracket next to we’re the front of the graphics card sits small of sort of long cause I don’t wanna put a normal gpu on to a small bracket andf with a bad oem power supply
Upgrades are good and bad. Good if they work and bad if they dont. Would you realy want to gamble with the life of your device like this?
Score -2
Voeg je antwoord toe
mrmac4 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 3,284
