Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
carrier unlock via hardware
So I have a phone locked the 3 network in the UK. I checked this with apple and with 3, which they both confirmed. However, despite trying a few different sims from 3, I can't activate the phone, it just keeps telling me that the sim isn't from a network for the phone. I've also tried sims from pretty much every other uk network provider to be sure as well.
So I suppose at this point, I'm wondering if there's something in the hardware I can change to make it unlocked?
Any help would be massively appreciated
Is dit een goede vraag?
Score 3
1 Opmerking:
Hi,
Have you tried y restoring your Iphone using Itunes? As per the attached link https://support.apple.com/en-au/HT201263
It may reset something in your phone. Just a thought.
door
Voeg een opmerking toe
3 Antwoorden
You could root it. This voids warentys.
Was dit antwoord nuttig?
You should contact your carrier so they will contact Apple to remove the SIM lock policy. It is impossible to lose the lock from hardware. The only possible workaround from us is to use a SIM spoofer to fool the activation and lockdown. This will have side effects, mostly connectivity issues.
Understanding the iPhone Lock and Your Options
It's frustrating to encounter this issue. Based on the information you've provided, it seems there's a discrepancy between what Apple and 3 are telling you and what's actually happening with your iPhone.
Why Hardware Changes Aren't Feasible
Before we delve into potential solutions, it's important to clarify that hardware modifications are generally not a viable option to unlock an iPhone. This is due to the complex security measures built into the device. Any attempts to bypass these could potentially render your phone unusable or even brick it.
Possible Solutions
  1. Double-Check with 3 and Apple:
    • Ensure that your account with 3 is in good standing and that there are no outstanding balances or restrictions.
    • Verify that the iPhone's IMEI number matches the one registered with 3.
    • Request a detailed explanation of the phone's lock status from both Apple and 3.
  2. Check for Carrier Updates:
    • Sometimes, network carriers need to update their systems to recognize unlocked devices. Check with 3 if there are any pending updates or if they need to manually unlock your phone.
  3. Consider an Independent Unlock Service:
    • There are third-party services that specialize in unlocking phones. However, exercise caution when choosing a provider, as there are scams. Ensure the service has a good reputation and offers guarantees.
  4. Purchase an Unlocked iPhone:
    • If all else fails, purchasing an unlocked iPhone might be the most straightforward solution. This way, you can use any SIM card from a compatible network.
Voeg je antwoord toe
lukeandrewbradshaw zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 1,245
