Ga door naar hoofdinhoud
The Nokia 1100b RH-36 was released as part of the Nokia's 1000 series of "Ultrabasic" phones in 2003. It's simple design possesses minimal features beyond the ability to make calls and send text messages.
Vraag afgerond
Using Nokia 1100 without battery
Hi, is there someone that could help me to use a Nokia 1100 without battery, connecting directly to power supply?
Thank you very much
Giuseppe
Italy
Update (10/25/2015)
Thank you Ruben, but I got the original Nokia power supply.
I need to connect directly the power supply to the phone without the battery.
I tried to connect the power supply removing the battery but doesn't work.
I wish to understand how to connect directly the power supply to the phone electronic circuit.
Could you or someone help me?
Thank you very much.
Giuseppe
Is dit een goede vraag?
1 Opmerking
Giuseppe I am wondering why you would want to do that. You can charge the battery outside of the phone with an external power supply. So why not just buy a new battery? What are your intentions with that?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hello! If you have a variable power supply you can do it. You have to adjust power supply at the same battery voltage.
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,023
