Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
Touch screen not responding
My iPhone 5C fell off and the touch stopped working. There are no cracks, but sometimes you can see a brown (red?) grind pattern (image included). I found one topic connected with this problem and one member wrote:
I had this issue recently, where after a complete digitizer replacement, the phone turned on and looked great, but it no longer responded to touch and there was a strange grid pattern on the display. It turns out, under the adhesive piece that covered the digitizer's attachment to the main logic board, there was a tiny fuse that had fallen off. I am now looking for a micro repair place that can reflow this fuse back onto the main logic board. Make sure there isn't some other hardware damage.
Touch screen problems after screen replacement
Can anyone explain this to me? What can I do now? Can I see it (fuse) on some photo?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Yeah, it's an issue with your digitizer. You could try taking it off and putting it back on. It's a thing I do, when a new one isn't co-operating. If you try this and it doesn't work. Remove the cables, disconnect the battery, reconnect the battery, then reconnect the display cables
iPhone 5c Screen Replacement
Worst case scenario you could buy another one from here
iPhone 5c LCD and Digitizer
Replace a scratched or cracked front glass digitizer panel or malfunctioning 4.0 inch 640 x 1136 pixel IPS LCD compatible with the iPhone 5c. Afbeelding
Product
$39.99
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you, I will try to do everything you mentioned after I get some stuff (pentalobe screwdriver) and I will post the results.
door
I have the same problem. Can you explain where is the fuse on the logic board and if the repair has worked ?
Thanks
Voeg je antwoord toe
iK0X zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 1,277
